Can't gas it, any ideas
Honda
I'm working on a 2007 trx250ex that was slightly flooded in hurricane ike. Oil change, all done, none in gas tank. It will idle fine but when I choke it it dies. If I give it any throttle it'll rev up for a second or two then die, almost like it's being flooded. Could it be something as simple as the spark plug? Or do you think it's in the carb..? Any suggestions would be helpful
I don't think it's flooded but rather starved for fuel. You probably have some oxidation inside the carb and it is in need of a good cleaning.
Probably a gummed up carb.....
