polaris predator air box replacement
Polaris
i have a 2004 predator 500. i got a pod type K&N air filter that fits right on my carb from my neighbor. i am wondering if i need to re-jet the carb or adjust it. or if i should just go with my stock air box.
You will need to rejet. Most people use a piece of alluminum tubing to mount the pod filter in the airbox with the lid off. I would highly recommend that with a filter cover like "Outerwears" to increase the fine particle filtering and help keep water out. They also make lids for the airbox. A jetting change is a definite requirement though as you will increase the airflow capabilities with the K&N causing your quad to run lean.
thanks for the help
