leaking out the overflow
Suzuki
hey i got a 04 ltz that i did the fcr mod to. and it leaks out the overflow when i shake the machine. so i know the float needs to be adjusted a lil i was just wondering if someone had a spec togo by. the carb is off a 05 yfz. thanks for the help
Float height 8.0mm (0.31in.)
a. Hold the carburetor in an upside down position.
b. Measure the distance from the front mating surface of the float chamber (gasket removed) to the top of the float.
NOTE: The float arm should be resting on the needle valve, but not compressing it.
