rebuilding raptor 660 motor
I have the motor apart on my bench, have the head and camshaft off. Looking at the piston and it seems like there is a large gap between the piston and the cylinder, I can stick my fingernail in between the two, when the other side of the piston is flush with the cylinder wall, is that normal? I will be measuring it later.
I bought a new piston and rings for it since it was burning oil, but the valves have also not been touched for a year, if the valves were off could it burn oil? About half a quart a week, as well as smoking on startup.
Should there be oil around the valves and camshaft? Or are my seals out? This is my first time taking apart this motor.
you probably have too much of a gap between your sleeve and piston
Yes, there should be oil around the cam and valves. The valve guides need to be replaced that is why it smokes on start up.
  • Similar Content
    • By kxrob
      Never heard about this
    • By Jturn
      38MM Cast SmartCarb. Purchased a couple years ago for a yz250. Don't have the bike anymore, and it has been sitting around for about a year. Used, but in fine working condition. You can also purchase a different needle for different bikes, as well as rebuild kits from their website.
      Asking $250 shipped to continental United States. I can arrange other shipping options at the buyers expense.
    • By Loper135
      So I am going to buy a brand new ktm 150sx. Should I wait until the 2019 come out? When does the 2019’s come out? It is March 22, 2018 right now. I have the cash already,but want to make the right decision. Thank you.
    • By MotoXRacer_19
      Does anyone know how to, or if you can, change your AMA number? The race number, not the full thing.
    • By Toby_S
      I got all of this stuff to make a second engine with electric start for my 2002 WR250F. Including complete electrical system.
      The only things that are missing is the left side case, and a battery.
      Included is a complete new valve train, and Hotcams. The valve seats were cut by my brother's shop, on a Newen machine, which is state of the art. I lapped the head on a granite surface plate - it's perfect.
      See pictures here:
      If you're interested, we can get into detail about it. I'm a serious mechanic, and I was totally going to do this, but I got a big bonus, and bought a KTM EXC 350 instead. Check my posts and history on Thumper Talk.
