Yamaha 1992 warrior, coil/CDi failure?
hey folks, have a 1992 warrior, quits when hot, the starts back up after as little as a couple minutes.
the negative battery cable has had a habit of vibrating loose, used a locknut to solve that part of the problem, I'm leaning towards either a coil issue, or a CDI issue.
also have read that a stator problem could cause the same symptoms
need some advice before I start throwing parts at it
tia
Rick, Ore :bonk:
