90 Big Bear - High RPM Miss
Yamaha
My fathers new to him 90 350 Big Bear has a high RPM miss and fouls plugs. Any ideas of where to look?
have you clened/checked the air filter?
i have a clymers for that bike if you need some specs.
Air filter is new. Does the Clymer manual have ohm checks for the ignition coil and magneto.
sry been away. i will check for you.
It is probably from a weak spark.
New plug installed. No change
