lt250r no spark what to look for
so i recently was trying to start my 1985 lt250r the other day after having it sit for a couple weeks due to a leaky needle and seat and it wouldnt start. it ran fine when i had it going before the needle and seat started leaking so i parked it cause i was wasting alot of gas. so me and my dad tried pulling it behind the other wheeler and it would pop but not start or run. we stopped and i pulled the spark plug out and there is no spark. so i started by unplugging the kill switch, that didnt do it. idk what else to try or where to start. any help would be greatly appreciated!! also, when i did have it running before it kicks back really hard when i try starting it and my dad said it might be the timing, its too far advanced he said maybe where do i set the timing at on the stator? is there a mark to set it at?
The timing is set at the crank with the key and is not adjustable.You said it popped? Like it was trying to start? You can check the coil and stator with an ohm meter. But they are known for shearing the key under the flywheel so I would check that also. There is alot of info at and the guys are very helpful to new guys.
  • Similar Content
    • By MotoXRacer_19
      Does anyone know how to, or if you can, change your AMA number? The race number, not the full thing.
    • By MrPickles
      I have a 1990 Suzuki RMX250 for sale.  It was bought from a friend who bent the crank back in 2000 and took it completely apart (down to the nuts, bolts, and washers).  The frame was powder coated black.  New crank case bearings, new gaskets for crank case, cylinder, and cylinder head.  All transmission bearings were cleaned and checked for wear or damage.  The crank was rebuilt and balanced by a local Harley shop.  New OEM piston and rings.  Cylinder and head are in excellent condition and worth almost as much as the entire bike, I think.  Brand new FMF Gold Fatty pipe.  New front and rear Renthal sprockets and new D.I.D. chain.  New grips.  Includes the original headlight and odometer (not shown), Mikuni TM38 carb has been cleaned and rebuilt.  Seat is original and in perfect condition. Runs perfectly.  Could use some new plastics, new foot pegs, front fork seals, rear tire, and a tune by someone better than I.  Pink slip in hand, but hasn't been registered in years.  Will throw in a Clymer manual.  The bike is a rocket and too tall for my 5'9" frame.  I'd like something a little more convenient to ride with my young kids. Asking $1800 OBO.  Serious inquiries only please.  Price doesn't include any shipping.
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By Christo6060
      Should I buy this bike my uncle just sold one and said in good condition they’re worth from $600 to $1200 and if I could get it for $300 it would be a good deal.
    • By Michael570
      Can anyone link me some aftermarket shocks and such. Im looking for racing shocks and I can't find any. Also I'm looking for a frame cradle for my bike. It's a 2017 but I don't think that matters.
