Another problem
Is the battery dead? Will it turn over or jump start? Did you check for a loose connection anywhere?
Check your electrical connections starting with the battery cables. Make sure that the battery cables are attached to the battery posts good and tight with no corrosion on the battery posts, the cable connectors or the cable strands. Anywhere there is exposed wiring, check for corrosion.
Ya those were the first things i checked but nothing happened still so i figured it was somethen else but after i posted this i went back and i guess it somehow got stuck between first n neutral so its fine now lol
