2007 vinson oil leak
Suzuki
I need help guys and gals,
On my 2007 Vinson 500 I have an oil leak. It's coming from a machined hole in the left side case cover. The case is painted black and sits in between the the case itself and the water pump. The hole is on the very bottom on the case and looks like there may have been a pin in the hole. It may also be a weep hole to let us know the gasket for the water pump is leaking.
Can someone please look at their case and tell me what you see. Is there a pin on a dry hole? I would really appreciate it.
Steve
