Mojave 250 no spark
Kawasaki
I bought a 2002 mojave a few days ago and it doesnt run. I looked at it and the ignition/key is cut on it so to get it to run would i just connect the two cut wires together. My quad also has no spark is there a way to diagnose the problem? i couldnt get the spark plug out because i still need to grind down a socket but i put a d8ea spark plug on it and i couldnt get it to spark. is there another way to do it thank just tryin to kick it over with the spark plug near metal? also i checked my coil and there is no cracks or anything in it. The quad also looks like it might have a crack in the crank case. will it still run if it has a crack?
