trouble wih an 04 z400
Hi everyone, hopefully someone has some input to as what my problem is with my wifes 04 z00. i took it out last friday for a few hours and again on sunday and rode no trouble until sunday afternoon. i was ripping around in a field hitting a small jump and just goofing about, i went to circle around & when i got back on the gas for my approach it bogged out, i pulled the clutch in and let off the gas and it recovered but when i give it some throttle it bogs out. At first i though air filter- checked it and its clean. i'm pretty sure its not the gas because i topped the tank off on friday and got a few hours riding in between the two days next i pulled the plug and its sort of whitish- thinking it's running lean i checked the fuel, on prime it flows through, under res and on positions i blew it back into the tank (because this carb uses siphon to pull gas) so i know that delivery isn't(or shouldn't be) the problem. i start looking at boots and intake and tightened them down to be sure. on the carb i found a small dia. hose thats connected to the carb but nothing else. it's on the left side just above a lemon shaped cover with two screws, the hose is bent and angles up and was sitting against the bottom side of the tank, could it just be a vent as i couldn't find something disconnected. Again this bike will start right up and idle but won't rev up and i can't find an easy solution, is it time to take the carb off or has anyone got any ideas or had a similar problem?any suggestions are welcome.
  • Similar Content
    • By Markl5557
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By SendIt
      Was wondering if a newer model exhaust can fit on my 05 RMZ-250. My stock exhaust is rusted out and I prefer the look of the new ones and have seen great reviews on some, as I also want more weight savings. I have been unable to find out if a newer model can fit on my bike, was wondering if anyone could help me out.
    • By ThomasM.
      hotcams shim kit that will fit most 450's.
      I used 3x 1.75mm and 2x 1.7mm shims. the rest is still there
      part# HCSHIM02
      $60 shipped
      will fit:
      2002 - 2017 Honda CRF 450R BIKE,2005 - 2017 Honda CRF 450X BIKE,2003 - 2004 Kawasaki KLX 400 BIKE,2008 - 2009 Kawasaki KLX 450R BIKE,2008 - 2017 Kawasaki KX 450F BIKE,2000 - 2016 Suzuki DRZ 400 BIKE,2005 - 2015 Suzuki DRZ 400S BIKE,2016 - 2017 Suzuki DRZ 400SM BIKE,2005 - 2017 Suzuki RMZ 450 BIKE,2014 - 2017 Yamaha WR 250F BIKE,2003 - 2016 Yamaha WR 450F BIKE,2014 - 2017 Yamaha YZ 250F BIKE,1998 - 1999 Yamaha YZ 400 F BIKE,2000 - 2002 Yamaha YZ 426 F BIKE,2003 - 2017 Yamaha YZ 450F
    • By JustAnotherGuy
      I have a 1992 rm250 and I need a new exhaust  , but I can’t find one for a 1992 so I was wandering what other years are compadable with eachother
