1990 Polaris Trail Boss transmission
Polaris
Hi,
I have a 1990 Polaris Trail Boss that has transmission problems. I was wanting to see if I could find someone that sold replacement transmissions. Aftermarket is fine. Thought it might be cheaper just to replace the transmission rather than rebuild the current one. Thanks in advance for the help!
Kurt
what kind of problems are you haveing? I just bought the same quad and mine will kick it self out of low range or when you put it in low or reverse it will just make a awfull noice like its grinding untill you step on the brake then take it out of gear and try again then it works. is this what yours is doning as well?
