need help with jetting.... PLEASE
I have an 07 Ds-650 Baja X i have a yoshi pipe slip on and a K&N filter. I do have a jet kit i bought on line its called mikuni and what came with the kit was 2 jets one is 175 an the other is 180 two little tiny washers clear spacer a drill bit and a screw. Is that right I mean is that all i need? I would like to install it myself with some help like someone who now's jet kits really good and i can take it where ever and all they have to do is tell me what to do or somewhere cheap and good to get it done. So if any one has any info then please let me know....
Jetting an engine properly requires a little more then installing a prepurchased kit. Why are you rejetting? Is the jetting off to begin with? Was the quad re-jetted after the installation of the pipe and air filter? Did you change elevations? There are many factors that require a jetting change, just throwing a jet kit in is not an accurate upgrade/nor will it give you any increase in power if it is not correct for your conditions.
