Sealevel jetting setups.
Hi gang...I'm jetting the KLX this week and was looking for suggestions about sealevel jetting in the pacific Northwest. It's a pain in the *ss to get into the carb so if anyone in the area is jetted well i'd love the input to save as much of the trial and error as possible. Is a fuel screw necessary or just advised. Thoughts?
Thanks in advance.:bonk:
I am in ontario and at 500ft above sea level
check out the detailed description in this thread
several posts down from top is mine
http://www.thumpertalk.com/forum/sho...d.php?t=812250
good luck - proper setup makes the beast come alive!!
Fuel screw is a must - do it right the first time and save yourself a lot of grief!
JD jetting kit, sealevel needle on middle clip, 165 main, stock pilot, flex fuel screw (Must have!) but the icing on the cake was the R&D fuel bowl... The R&D made the bike very crisp and I can tweak the leak jet (run 50/55 in the summer, 45 in the winter/fall).
But with out the R&D bowl it ran pretty good....
