clutch fluid
If you have the Magura system its plain old oil, ATF is light & cheap, no need to buy Maguras stuff, not advantage to one over another other than a slight advantage to a "lite" weight and no advantage to changing it.
If you have the Brembo system it uses brake fluid and should be changed annually as it is hydroscopic, meaning it sucks up water, then becomes corrosive
Agreed, it does suck up moisture. As for fluids, change them all out yearly and you'll be trouble free.
