2002 CR250 Fork Seal Replacement
Ok so I am doing my fork seals on my 02 CR250. I purchased the Pivot Works rebuild kit with all of the bushings, o-rings etc.
My question is, is there an upside and a down side for the seals? I thought I read somewhere that someone had put them in upside down and they leaked.
How can I tell which way is up?
Thanks.
It should be obvious which way they go, just pay attention to the removal of the old ones.
the letters go out, or toward the bottom of the fork. you will know which way they go.
Thanks guys!
You should be able to see this side of the seal when you've driven them in.
