CRF250X 280BB Porting?
Hello, I have decided to purchase the Athena 280CC Big Bore kit for my 2006 CRF250X, I was wondering what exactly porting would do and if I should do it when I get the kit. Thanks!
Your bike will run almost perfect....I needed a bigger pilot jet(45) for a smoother running low speed and I used a bigger main jet ...I think I went from a a 172. I don't know if porting will help much as the carburator will only flow so much. I guess it would maybe help midrange ,,,but wait until you install the kit.. Its quit a bit more powerfull. Specially if you ride off the mx track where torque and smooth power are your friend. You will lose some overrev and top end power.....not that much though. You will notice you have two more gears to use riding....4th and 5th are actually useful gears with the bigbore....Good luck....
I was wondering if I should do it when I have the whole engine apart and how much it will cost, I know it helps the airstream or whatever and would improve throttle response, but has anyone else done this with their Athena BB kit? Thanks!
just use a longer cam, most everything you read about porting and different year heads etc pertains to filling a 250cc hole efficiently at rpm. All bets are off with these mods at 280, and the rpms you'll run it at.
If you want a fast X, leave it a 250 13.5 piston and 08 cam are most cost effective. If you want grunt and pull and more lug and chug, do the big bore.
I would consult the known engine builders directly on this. porting may be effective but it would have to be done right to work with your specific combination.
Call Ron Hampe for his advise. The larger bore actually unshrouds the valves allowing better flow. Usually the stock 2008 Honda 250R cam works extremely well with a big bore, is cheap, and doesn't require any special springs and you know the quality is good. Cutting the air box and all the other free mods should be done along with proper jetting of course. Have fun!
  • Similar Content
    • By Connor Wright
      Hey I have a crf250x 2005 I was riding today in top gear flat out and when I slowed down blue smoke just poured out the exsaughst then I happened to open the air box lid and saw it has what looked like engine oil in it then took out air filter and noticed that there was splatters of engine oil on the inside and that and the channel that goes to the carby had engine oil all over it.
      Also bike got a top end rebuild 15 hours ago
      The engine still runs good and sounds normal
      why would this be happening on a resonabley fresh engine
    • By mikemcbride
      Hey everybody. Quick question for y'all. I recently went riding and about halfway through my ride my motor seized on my '07 CRF250X. I haven't investigated it much but I checked the oil when I got home and there basically was none so I'm assuming that was the culprit. There weren't any metal shavings in the filter or on the plug either. At this point I'm trying to decide to rebuild the motor or just sell the bike as is and let the next buyer deal with it (they would know the deal obviously.) I feel that I'm pretty mechanically inclined but rebuilding a CRF engine is a bit out of my league and I assume paying a shop to do it would put me out more money than the bike is worth. So, I have this question to ask; what would be a fair price for a pretty dang nice shape 07 CRF250X, with a seized motor with an unknown extent of internal damage?
    • By ThomasM.
      selling Hot Cams Valve Shim Kit that i bought for my 2005 crf250x, will also fit crf250r.
      used 1x 1.30 and 2x 1.55 shims. the rest is still there.
      $60usd shipped in the usa or canada
      please contact me for pictures or if you are not sure if it will fit your bike
    • By TerryA
      I have two rides in on my new Rekluse auto clutch and I have to say I'm very pleased. The install wasn't hard, but was pretty much a all afternoon sort of project. I also installed a left hand rear brake kit and a two finger cluth over-ride with the adjuster on the perch (which I rarely seem to need). It has all worked great right from the beginning. After struggling to get up a tricky hill in first gear, I tried it in second and the autoclutch helped me clean the hill easily. Not having to worry about clutch action in techinical sessions has also eased fatigue and just made it more fun all the way around. I ride mountain bikes alot, and having both brakes up on the bars has also been nice as it makes for a set-up just like the bicycle - in fact I like that as much as not having to worry about clutch manipulation. The brake on the bar is especially nice on tricky downhill sections where you need to paddle, such as nasty rock/rut stuff. So first impressions are that it was worth the investment -making the ride more enjoyable and easier at the same time!
    • By Mikey560
      I was driving the bike for 15min or so and all of the sudden the bike stalled. I tried starting it again with no luck. I took the spark plug out to see if there is spark so i ground the spark plug to the frame and there is no spark. I even put a new spark plug in the bike and still nothing. Any ideas what i should check??
