Taffy mod on my Z
Bear with me here :bonk:
Complete noob
I have an '05 E..as I understand I have to do the taffy mod on it..not the O-ring right?
I have searched but the results are sketchy
Is there a documentation of the taffy mod in a post plz?
Thanks :bonk:
click click
I read this first http://docta-zaius.freeservers.com/whats_new.html
Then i bought these...
Then i cut off one connector with a hacksaw and removed the plastic. Go for a 5amp connector i think, the smallest ones. And used it as the adjustable stop.
You can reach it when the carb is on too for adjustment. Although the best way is to set it with the carb on the bench by videoing it then playing back on your pc with vitual dub mod (free) to see the exact duration.
Hope that helps :bonk:
I did this a couple months back on my E model using a RC car collar lock. I first followed the instructions linked above and did the mod with carb on the bike and set the gap to a dimes width. It showed some slight improvement but not all I was looking for.
Ultimately I needed to pull the carb and set the squirt to about 1.5 seconds to get the results I wanted. A small PITA but the results were worth it to me.
So is it just that little copper screw thing that you put on? No needing to adjust the seconds somehow?
Thanks for ze help
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
