Replacing Clutch cable
Hi,
Any Tips to replacing the clutch cable, is it easier than it looks.
The cable seems to go down the middle of the bike, and at the gearbox end, doesnt look llike there is much space to hook the new cable on.
Do I need to remove radiator cover and petrol tanks???
Thanks
You need to remove the tank. Pull the tank and shrouds in one piece (keep them bolted to the tank and just remove the single bolt at the lower radiator mounting point). Route the new cable in the factory location as you remove the old cable.
