How to drain the coolant around cylinder?
I volunteered to have a look at my buddy's 90' yz125, which has absolutely no compression, and is in roughshape. I am currently trying to take the cylinder off to inpect the piston and walls, but i noticed when i took off the head cover, there was still coolant in the holes surrounding the cylinder. I did drain the coolant from under the pump, and most of the hoses leading to the rads i have disconnected, so how the heck do i get that last bit out? I dont want to take the cylinder off and have the coolant
go into the crank/bottom.thanks for the help!
try taking a syringe or turkey paster with a tube on the end and suck out all the coolant.
The coolant drain bolt should drain all of the fluid, maybe try to kick the bike over so that the water pump will pump the fluid out of the cylinder?
  • Similar Content
    • By Rick Mcqueen Art
      A tiny clear rubber tube on bottom of carb.  On bottom sort of on side, by floats, the other end just hanging down.  Was it always like this? Or does the other end go somewhere?  Today after multiple trys with kick, choke on/off ,,,fuel keeps pouring out the tube.  This bike has always been hard to start.   Thanx  guys!
    • By Brock granberg
      I just did my valve adjustments and put my YZ250f back together as far as the valves, shims buckets and cam covers on but I need adhesive for the plastic valve/cam cover and I am stumped as far as what to use and where to get it or even what to call it! Need to get some soon im in need of a ride!
    • By ThatE30GUY
      Hey guys, I bought this YZ85 and came to realise the clutch wasnt working, so I drained the oil (Jet black) and pulled the plates out and cleaned them. I assumed finding a torque wrench would be easier than it has been. Does anyone know how to torque the clutch springs to spec without a wrench? Any insight helps.
