No power at wot
When I open the throttle and rev the shit out of it in first, I get to about 60km/h or so and when I change up to second and just adding throttle it delays.
Normal?
Are you sure you are not just hitting the rev limiter in 1st?
No idea :bonk:
You are hitting the limiter, shift earlier.....
Look in the FAQ for the gearing chart to get an idea of how fast you can go in each gear and then you will have a pretty good idea if it is the rev limiter.
