Idle 1998 yz250
I'm new to the forum,so hello everyone
I have a question about correct idle adjustment.
When I start the bike cold the idle appears to be normal after about a minute or two when the motor warms up the idle appears to pulse up and down, goes into some kind of cycling with pinging. When I adjust the air/mixture(richer) screw the idle returns to normal no cycling/pinging, but the pilot air screw is now turned in, all the way. The bike will continue to run for about 2 and half minutes the carb will load up and finally turn off. Do I need to change my Pilot jet or Jet needle postion. Jet needle postion is second from top.
thanks, for all help that is given
Edited by Brandon100XR
you need a larger pilot jet, so raise it to the one above the one you have now.
Thank you FoxySox, I changed the pilot jet. The previous owner had a #42 and I changed it back to stock. #48. I will try the changes later tonight.
48 will most defently be to rich ( like everything from the factory) it should run its best between 1 to 2 2/4 of a turn out, hope it helps
