Check this out...
The other day it was cold out and I was warming up my bike and noticed exhaust steam coming from this little hole on the bottom side of my stock muffler. Did I lose something or is this supposed to be there?
Thanks in advance.
Photos below...
Supposed to be there.
Weep hole if you get water in the pipe.
Mine did the same thing. I ran to my puter to see what was the matter.
TT saved me again.
Thanks guys - what'd we do before TT?
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
