spark plug
wr 250 f 08 how can i get my spark plug out easy i cant seem to get the cap off. does any one know a trick.
Twist and lift at the same time. Or if that does not work try LIGHTLY prying between where the lead plugs in the coil and the valve cover. To prevent this from happening again, get some dielectric grease and coat the the whole coil and where it plugs on the spark plug. Protects against moister and makes pulling the coil out a none issue.
if that don't work for ya, take a blow nozzle and compressed air and blow into the little drain hole on the side of the head (center of the head on the right side of the bike) Compressed air will blow it off every time.
