best needle for stock 05 kx250
Where'd you hear that?
quote from MXA "It was a good thing we tested the 2006 KX250 in the heat of summer. If it had been winter, with more oxygen in the cooler air, the KX would have pinged itself to death. The jetting is lean, even for normally rich 100-degree weather. We replaced the 160 main with a bigger 162-and could have gone richer."
I could believe that because with almost every youtube result of an 05, the bike pings. http://www.youtube.com/watch?v=t-W6XiBOAK8
What temperature and altitude are you jetting for?
right now cooler weather, 50 degrees, and whatever the altitude of PA may be
Well, Pro Circuit and Team Green recommend the stock needle on the 05.
My bike doesn't ping, and I'm running a 155 main, stock needle and a 45 pilot. Albeit, I plan on going to a 160.
Hm...would you say the bikes sounded lean in the 2 vids? especially the second one it sounded horrible
Dude, the last thing I'm gonna jet my bike by is a video from Youtube. Ride your bike and look at the plug. :bonk:
According to the table from the manual, you should be running the following:
Needle: NTFG
Pilot Jet: 50
Main Jet: 160
Clip: 2nd clip
Airscrew: 1.5 turns out
If you're closer to see level (this is for 1000m) ,
Needle: NTFG
Pilot Jet: 52
Main Jet: 164
Clip: 2nd clip
Airscrew: 1 turn out
You can use this calculator, just convert your altitude and temperature to meters and degrees Celcius
http://www.mediafire.com/file/tnggwznztjn/Jetting Chart REV 2.xls
Needle: NTFG
Pilot Jet: 52
Main Jet: 164
Clip: 2nd clip
I'd leave an oil slick running a 52 pilot.
the manual totally baffles me, but maybe real riders are so much faster that their settings are not insanely rich, or maybe the spark arrestor requires much leaner jetting.
on my 2007 i have found that the nalx or nafx series needles suck less than the nftg, but so far for my riding style i prefer the jd blue. it runs cleaner off-idle and hits less suddenly.
not sure how applicable it is to the 2005 (which may also need airgap adjustment to help the ping), but for fall in idaho (3000-5000', 40-70 degrees), i'm currently running a 38p, jd blue #4, 160 main.
nafh#2 and 155 main also works well , but is not as clean for low-speed lugging. This is with a gnarly pipe and q-silencer, but as far as i could tell the jetting requirements were about the same with the stock pipe. I only put the gnarly on 2 weeks ago.
Mine came with a NALF but the jetting was FUBAR so I went to stock as a starting point to sort things out. I have the clip at #2 and have had good results. I may try the NALF just to see what difference it makes.
