dowel pin in cases
what is that one used for is it just for centering? not the the one in the case halves but the one on i guess on the oil pump?
note: its the one on the internal part of the oil pump
if you are speaking of the one in the middle of the bottom end with an o-ring around it (if you look at the case halves you will see an actuall flat o-ring boss around the outside of the dowl hole).....Is that the one you are talking about? It is not a locating dowl, it is more there to simply make sure the o-ring that seals the 2 case halves right there stays in place upon assembly....
If this is the one you are talking about, make sure you do not get it mized up with the locating dowl pins for the cases as it is actually a different length that those (if I remember right).
MK,,THATS THE ONE!:bonk: your wife take care of that refund yet!?
Good to hear I hit the nail on the head...and yes it is not the same sze dowl for length....
I will give her a yell and see...if not I will make sure it gets square....:bonk:
thanx MK!!:bonk:
