spark plug
Can having a old spark plug, that still works affect the power?
Yes it can. an old plug that isnt gapped properly will kill your power. spend 3 bux and get a new one.
does getting a more expensive spark plug make it run better?
Not necassarily. The plug could be more expensive but if it's too hot for your bike it could mess up just as easily as a cheap one could. For example i run a 50:1 ratio (i know not enough oil, but it works) when i used the $12 plug that i'm supposed to it runs for maybe a day then it fouls. But when i run the cheaper version it hasn't fouled yet and it's been at least 10 rides. It all has to do with the ratio you're running.
whats the best fuel ratio for a 2000 cr125?
Where are you getting $12 sparkplugs????? i hope your not buying sparkplugs from the moto shop. I get mine from autoparts stores. you can get NGKs for less than $3.
pretty sure its 32:1
yeah any leaner than 32:1 on a 125 is risking damage when ridden properly.
