Does the 04 cr 125r rear shock fit on a 04 cr 250r ??
Hello . I was wondering if a 04 cr 125r rear shock will fit on a 04 cr 250r ?? If it does Ill pick one up on ebay.....
replies will be very much appreciated . Thanks !
the 125 is KYB and the 250 is Showa, you need to know the length eye to eye. I know for instance that my 03 CR125 shock was 10mm shorter than a CRF250 shock. I ended up having mx tech switch the clevis' on the bottom when he did my revalve to make it work.
ok, thanks .
Funny you ask this.
I run 02 cr125 SHOCK ON MY 02 cr250.
It raises the CR250 rear end several inches.
And I like it.
No more stinkbutt ride for me.
You should see the same results.
The CR125 shock is longer then the CR250 shock.
