'02 RM 85 jetting
I currently live at sea level in southern ca.
When I roll on my throttle, there is a gurgling build up then as the bike gains momentum it seems to get through it a pulls well up top.
Is this a pilot jet issue? would it be too big? Does richer = bigger? Do I need a smaller pilot. Are pilots called a "slow" jet?:bonk:
Thanks for your help.
you open the throttle fully,it gurlges then clears out and goes?
Yes but is really loaded up on the bottom, never clears up down low. Gurgles and blubub
Many people mistake carburation or jetting problems with needing a new top end.
I see this every day.
When I tell people this I usually hear, "We just put a new piston and rings in it".
Sometimes you can put a new piston and ring in a bike and it's fine.
If your bike is more than a few years old a piston and ring job is not usually enough.
A cylinder can look great and even pass a quick mic job.
However, unless you have experience with a mic and unless you have a decent set of mics that are properly calibrated you are better off letting someone mic your cylinder who has the proper experience.
A measurement of .0005 (4-6 times smaller than a hair off your head) or less can be the difference it a cylinder that can seal with a new set of rings and one that wont.
If your cylinder does not pass a careful inspection, then it will need to be repaired and re-plated or sleeved.
Once your top end is correctly repaired, do a compression check.
If it does read at or better then factory specs, no amount of jetting will help, really.
Also, be sure your reeds and exhaust valve assembly are clean and in good repair.
Last but not least, check your Carburetor boot to be sure there is no cracks.
  • Similar Content
    • By Rick Mcqueen Art
      A tiny clear rubber tube on bottom of carb.  On bottom sort of on side, by floats, the other end just hanging down.  Was it always like this? Or does the other end go somewhere?  Today after multiple trys with kick, choke on/off ,,,fuel keeps pouring out the tube.  This bike has always been hard to start.   Thanx  guys!
    • By Doukis1
      New spark plug, new air filter. Went for a ride and all was good. Hadn't run it in a week and a half. Now it won't start. Getting spark. The plug is dry. Is it possible I over oiled the filter and it has somehow gummed up the carb/ float? Thanks
    • By mbennett95
      My 01' yz125 seems to be requiring a large amount of throttle to get off the line. I've ridden plenty of properly jetted 125's and none required quite so much throttle work from a dead stop. Even slipping the clutch it wont get going without a pretty healthy amount of throttle. Thinking it just needs a clutch rebuild kit and maybe a basket. Any info appreciated!
      If it helps any here is what it has done.
      FMF Fatty, VForce 3 reeds, and an iridium plug.
    • By Sam W.
      Hey all, I just bought a street legal 2005 WR250F. Took it out once three weeks ago. Did about 60 miles on the dirt and 15 on the road, bike ran great. I took it out this past Sunday and was about 75 miles into my ride when the battery died. The battery is cheap, but it is brand new and was on a battery maintainer the whole time while it sat in the garage. I kick started it, and it fired right up. I was on the road for about 5-10 miles in fifth gear when I felt the bike slow down a little bit, and I noticed the sound coming from the bike sounded a bit deeper than usual. About a half mile later the bike started to bog down like it was out of gas. I filled the tank back up and experienced the same problem. The bike began to bog down, then puttered out like it was out of gas. Eventually the battery completely died and I was not even able to kick start it. I trailored it home, hooked it up to the maintainer, waited a couple hours, and the bike fired right up with the electric starter and the choke out. However, it was still puttering a lot when it was idling at this time. If anyone knows whats up, I would appreciate any and all help. Thank you. #Yamaha#wr250f
    • By Ndh87
      I’ve got an old barn find ‘83 CR80R that needs either a new carb or a rebuild kit. I haven’t been able to find either anywhere.
      Does anyone know where I can find either?
      housing, bowl and all the hard parts seem fine, if I can find a rebuild kit with a new float I think I’ll be ok. Right now it runs but only when I leave the choke on, smokes heavily and likes to bog down on takeoff
