desert gearing
Im looking to put new sprokets on and chain and i want more desert gearing for top speed. I have a 2005 crf450x with stock gearing(13 51). I can do about 85mph but id like mabe 95 or so tapped out or mabe 100 complety tapped:ride:( i like to go fast btw). so what do u guys recomend??? i was thinkin 14 50 but i have no idea what to put really:bonk:. So please help!!
Also will a 2003 450r cam fit my bike?? If so what will it do?? improve? Also what else can i do to the engine to make this bike absolutly rip in the desert, please help
- Cam works great. More mid to top.
- What tuning have you done so far?
- Suspension upgrades make the biggest improvement.
I have the stock front 13T sprocket and a 48T on the rear and I get very good hill climbing power but a lot more speed on strait lines. Open airbox and took out the entire baffle on the stock pipe. BTW I ride baja like this and it rips.
If you opened the airbox and the pipe, you need to rejet. You are running very lean, and are down about 5+ hp until you do.
Iv done jetting and opened up the airbox, only on sides though, going to do the top before i ride again, iv taken the baffel out of the stock pipe but will soon be getting a new pipe. And the suspension has been done already so thats why now i want to focus on motor. So mabe i should try like 13-48 or 14-48 or something like that? What kind of speed would that give me, does anyone know?
14/48 would put you in the mid 90s...the is a real good setup for desert riding. You can even go with 14/47 and 14/46 might get you to 100 screaming on the pavement.
I like 14/48. It spaces 2/3/4 out nicely, leaves a low enough first gear for almost anything, and has plenty of top end allowing for higher speed cruising. Great all around gearing on the 450X.
ok thanks guys, i think im going to go with the 14-48, cuz i just hate how short the gears seem with the 13-51, and i think mid 90s will be good, it will blow away my bros bike. thanks for all the help guys
What do u guys recomend for brands? I was thinkin turner steel sprockets cuz i know they will last forever and im not to worried about the weight of them and as for chain a DID ERT Gold 2.
i run 15/47 for Baja, and 14/47 for D37.
i run ironman or sunstar steel sprockets.
i rum 13-47 and really like it. RMA sprockets
R pipe, air box mods, and jetted.
Edited by yz58
im going to run 14-48 desert and and 13-48 woods with completly opened air box( right now it has just the sides open), and im getting a pipe soon( lexx mxe), and i already have a jd jetting kit ( 165 main, going to 170 possibly after pipe and air box mod). What do u guys think?
Sounds like a good plan. 170 might be a bit rich at sea level, but better to be rich than lean. Avoid motor mods if you can. Unless you're competing for a national championship, there's really no need to change the motor, especially if you like to trail ride. The R head makes the 450x a speed demon, but not necessarily the most usable power on the trail.
Invest in a good steel sprocket and o-ring chain. Ironman or Sunstar sprockets are the way to go. Never use aluminum... you're just wasting money. Regina or DID chains are the way to go.
Good advice, Justin:thumbsup:
I have a 170 in mine now with all the modifications mentioned above. runs great smooth power delivery.
im running 15/47
yeah im just going to play with the jetting to see what works best. I ride in mojave desert alot and in the moutains so im not right at sea level, a little higher. Also im not doing any motor work, its to expensive and it runs strong now. Only if i could find a good deal on r parts would i change them out. And ill be running some steel sprockets, i never run aluminum, its a waste of money to save such little weight, hopfully i can get ironman and then use a DID chain, and i also might run a r pipe but im likeing the lexx alot, plus its cheap and seems to be good quality, plus its tuneable. Well thanks alot for all ur help guys, made my desicions alot easyer. Thanks
Should i go with a DID o-ring chain? Or a DID ERT GOLD 2 chain? for desert and off road riding
  • Similar Content
    • By cmckay4
      Anyone having or had problems with the starter not turning over easily on the 450X???
      I have read about this problem on CRF's ONLY and not seen anyone come up with a fix.
      Problem being is that you think there is a problem with the battery, when infact the battery is OK. When you have a good fully charged battery in the bike and press the e-start, it turns over very slowly.
      I have checked the electrical circuit and it seems OK. I am wondering if it might be the starter itself - any suggestions?????
    • By Dust_Devil
      I'll start, if you see the "Fox Sticker" out in the Dez you know you crossed paths with ol' DD.....
    • By JohnnyAirtime
      Guys and Gals...
      Post your links to any of your pictures in this thread....
      (proper placement of pictures is in the "picture" threads)
      Post your links to any of your ride reports in this thread....
      (proper placement of your ride reports is relative to the area you live/ride)
      NO TECHNICAL issues, questions or comments in this thread.
      (it'll be deleted to keep this thread clean and with only the above listed).
      Please follow this format;
      Ride Report: Gorman, Tuesday 4-17
      (by Skoot22)
      Pictures from Ride: Baja 4.14.07
      (by Johnnyairtime)
    • By dakynz
      Guys, because of a member ban the jetting database has been removed. Let's start a new one to get this great information created into a sticky for everyone's benefit. Please stick to the information below.
      Temperature Range:
      Smog (AIS):
      Airbox Modified Top:
      Airbox Modified Sides:
      Backfire Screen:
      Air Filter:
      Pilot Jet:
      Main Jet:
      Needle Clip Position:
      Fuel Screw Type:
      Fuel Screw Setting:
      AP Modified:
      Leak Jet:
      AP Cover:
      Exhaust Type:
      Exhaust Modified:
      Pink Wire Modified:
    • By 2can
      I've studied the Jetting sticky's but still have a number of questions:
      I bought my '06 a couple of years ago and had a smog block-off kit installed and the pilot jet was upsized to a 48 and the air box opened up top only. The bike has appeared to run a little lean at times and got hot on a couple of occasions in elevation and on one other occasion. I'm looking at upping the main jet to either a 165 or 170 to help with the possible lean condition. The bike currently has a 142 main jet in it which I believe is the stock size. It looks like the most widely used Needle Jets are the JD Red, but it doesn't look like they are sold separately, is this correct?
      I was going to also get a 45 pilot to have options for further tuning. My assumption is that every bike is a little different and that where you ride is going to have a lot to do with jetting. We ride mostly, mojave desert, baja, and southern Utah with elevations from sea level to 9,000 feet but the higher elevations are generally for a short period as we generally continue through the peaks and head back down.
      I'm looking to convert from a stock exhaust to possibly an FMF Q4. I want something a little throatier but not overly loud and will provide a balanced flow of intake/exhaust.
      So can I get the JD Red Needle Jet by itself or can I get by using the stock and move the clip and be just as happy. I'm just looking to enhance overall performance of the engine and maintain reliability.
