Indicators not working.
It's a 99' xr250r it is road registered with indicators working but now they have stopped working. The haines workshop Manuel is useless for the indicator wiring of indicators. I have checked the wiring connections and bulbs and everything seems alright. What makes the blinkers flash could that be the problem? Any ideas would be great.
Check for 12V at the flasher input terminal, if there is voltage in, none out, flasher is shot.
You wouldn't have a picture or diagram of what the flasher looks like? I am not sure what to look for?
Does the Haynes manual not have a wiring diagram, or a photo of the flasher? Check with a Honda dealer. A flasher is usually a plug-in device, and easily changed.
Good luck!:excuseme:
