phantom throttling
Has anyone ever had this problem? I just picked up a 2004 DR-Z400S and took it out for its first ride yesterday. I rode through some pretty technical areas in 1st gear. From time to time, the engine continued to rev after I had released the throttle. I had to neutral it and rev a few times to get it to come down.
Second issue, which may be related, during normal riding I get spitting from the exhaust when I release the throttle. I say spitting as a mild use of the word backfiring.
Any suggestions?
remove the carb and clean it thoroughly , the pilot jet is blocked .
lube the throttle cables and make sure the throttle closes correctly
A hanging idle is usually a symptom on a lean condition.
I agree with the possible lean condition.
And popping on decel is normal.
If it has been sitting for a while.... The pilot jet is most likely clogged, and needs to be cleaned/replaced....:excuseme::thumbsup:
Do all of the above and then check for proper jetting for your elevation. This can make a huge difference....
Thanks guys, the bike had been sitting a while. I will bust into it this weekend. Appreciate the feedback!
Super......Let us know how it goes....:excuseme::thumbsup:
Another similar issue I have experienced was my throttle cables were "crimped" or constricted with my wiring harness behind the headlight which created extra throttle when my bars were turned to the right, so make sure nothing is restricting its function as well.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
