2- stroke ??s
Hey guys,
I have a friend that wants to trade me his CR for some stuff I have. The bike blew a head gasket and he replaced it but he said it doesn't run like it should now and overheats.
I cannot remember if it is a 125 or 250 but know it is a late 90 early 2000ish model.
What should I be looking for on these bikes potentional problems? I have not owned a 2 stroke since the early 80'ies and it was air cooled so a water pumper is new to me. I would hate to get it and end up with $1000 in repairs.
Any advise you can give will help.
its a 2stroke and cheap to fix. over heating you need to check whatter pump fan blades make sure they spin when you push kick start down. and make sure it dont spin by hand. grabe it try to turn it. blades should not spin by hand. and its seal. see if it has whatter in the oil. that will tell you if it is the seal. cant be much more then that. hope all gose well.
it would be a plus also if he had the tittle also, maybe you can take some pics also?
I will find out what it is on Sat. As for the title...North Carolina does not issue titles for "Off Road Only" bikes. I would have to register it in another state to get a title. What he wants me to trade I will be getting the better end of the deal. Since he asked for the trade I don't feel so bad about it. I just need a bike to chase my son around. I had to sell my XR and we have not been able to ride because of that.
Worst case I could sell it.
What is a 'whatter' pump?:bonk:
Good luck, fellow truck driver!:excuseme:
if the little ones in the house. as in kids. want to play on the computer. by typeing wile i tell them words. to type in for me. and they miss spell a word. and for you to pick on anyone for this. regardless of who it was me or them. makes you pretty LAME (also) in the future. if you fill the need to pick on. me or any one for this matter. you send them a pm. insted of screwing up some ones post. that needs help thank you........you all ant pushing my buttens any more Edited by MIKE ANIMAL
If the bike was running well before the head gasket replacement your friend probably put the head gasket on upside down.Try a new one first it's cheap and easy.
Well the bike is on my trailer. It is a 1999 CR125. It cranks first kick and seems to run OK but I have not been able to ride it since I'm at work. What I did notice while riding up onto the trailer is this:
Oil leaking from the head bolts
Coolant coming from the over flow hose about every 30 sec to a minute for a short 1 second spurt
No front brakes.
He stated that is has a larger bore than stock but cannot remember what the guy he got it from said it was.
It has a Pro Circuit expansion chamber and mini silencer.
Reeds are marked "V-Vorce" power reeds
Apears to have a larger front rotor with a Gold colored caliper relocator bracket.
I will post up a pic when I get home tommorrow.
have been known to have crank bearing issues. water pump seal will leak and use trans oil. I wore out an 86 model in the arly nineties!
Well here it is.
First thing is to take the spray paint off the plastics. :cheers: Easy with the paint stripper I have in the garage. :banghead:
Bike will be all white when it is done.
Well it idles well and top end seems good but it boggs bad on take off, like you are starting in 4th gear.
Any ideas guys. I'm clueless on this engine.
Last 2 stroke I worked on was an air cooled Suzuki DS100
like you said just clean the engine up, take the carb off, clean all the paggages including the main and pilot jet (could be clooged) with a water hose and air compressor. See what jetting specs are in it first, then go from there, not sure if you put fresh gas in it or not bu if you did not, drain the fuel tank, take it off, put a little fuel in there, swish it around, drain that and install the tank and put in fresh fuel.
what is your fuel to oil ratio
Well the fuel is fresh. The PO was riding it up until he traded me.
The engine has issues. This is not a fuel issue. as I stated in the previous post it is pushing coolant out the overflow hose and oil from the head bolts. Another rider here said something about a stuck or broken exhaust valve. Until I looked at a parts break down I was calling bull S&%T. I see now it has 2 of them that look like reeds. ***?!?! Anyway he said they will make it not pull off the line. I really need someone to teach me about this thing. Over the years I have been giving advise to people with the XR650L and now I'm the complete noob with this bike.
I will really start working on it after Christmas. I'm just doing little stuff right now between jobs.
  • Similar Content
    • By ashfmxuk
      So Been rebuilding my bike and the rubber mallet just "wouldn't cut it"!!!!
      I had to pry managed to sand down it all looked flat but this seems a bit gappy.
      This is only on the outer edge but I can help worry this is going to leak or get shit into the engine.
      Any help or advice would be awesome thanks
    • By Kaito Sutton
      Hey guys, so cant find much online about cr 250r enduro conversions (nothing recent) so im wondering if it is an option or not. I currently have a crf 250x 2009 and a XR 650r. If i want a 2 stroke enduro but want to stick with the honda line up, is a 2007 or 2005 honda cr 250r a good option. and if so what would need to be done to it to get it up to spec for trail and enduro riding. Thanks very much
    • By dirtbikesrule
      If you own a 2 stroke dirtbike,please reply once. Im just wondering how many people on this site have them.
    • By skipn8r
      Note: This specifically applies to the '92 - '01 CR250 engine, but it should be adaptable to any 2-stroke. The basic idea is to pull the carb and exhaust, plug one and pressurize the engine through the other to look for leaks.
      It's very important to pressure test a 2-stroke after it's assembled. The reason is that a 2-stroke gets it's lube through the pre-mix. An air leak means your engine can run lean. Lean means too little fuel. Too little fuel means too little lube. Too little lube means death to your engine. So here we go.
      First, you need to pull the seat, tank, shock, carb and pipe. Everything you need (other than a tire pump) is shown below.
      The assembly below is basically a 1-3/4" PVC plug (same OD as the intake pipe ID) that is transitioned down to a 0-15 psi gauge, a shut-off valve and a Schrader valve (to connect a tire pump). The 1-3/4" PVC plug is a tight fit in the intake pipe, but it'll fit with enough persuasion. I used yellow heavy duty pipe tape (made for gas systems) to put everything together. I don't have all the technical names for everything, but if you take the pictures to a hardware store, they should be able to help you piece it together.
      The item below is an adjustable rubber freeze plug. They are available at automotive parts stores in various sizes, but the closest one I could make work was a 1-3/4" version. You tighten the nut which squeezes two metal plates together which squeezes and expands the rubber piece between the plates. You have to tighten it a lot, but it makes a good seal in the exhaust port.
      Before you install everything, make sure that the piston is at BDC (so that all the ports are open), the spark plug is installed and all other components are properly tightened. Below, you can see the gauge/valve assembly installed in the intake pipe. Make sure to tighten your intake pipe hose clamp tightly as the pressure will tend to push the assembly out.
      Below, you can see the freeze plug installed in the exhaust port.
      Once you have everything installed as shown, use a tire pump to pressurize the engine to 6 - 8 psi, then close the valve and watch the gauge for any pressure drop over a 5 - 10 minute period. A well sealed engine will hold pressure with no observable pressure drop for 10 minutes easily.
      One common "leak" in a healthy '92 - '01 CR250 engine (and probably other types) is through the powervalve linkage. It probably doesn't affect performance, but it'll sure throw your leak measurements off. To avoid leaks, make sure the powervalve linkage is correctly lubed (per the Service Manual) with grease and Moly 60 Paste during assembly.
      If your engine holds pressure with no observable drop for 10 minutes, you're good to go. If the pressure drops 2 - 3 psi or more over 10 minutes, spray soapy water all around the pressure test parts first to check for leaks there. If you find none on the test setup, start spraying the soapy water around the base gasket, head gasket, center gasket etc. Any pressure drop of less than 2 psi over 10 minutes is your call, but I'd definitely fix it.
      I've had really good results by using Permatex Copper Gasket Sealant on the base gasket, PV cover gasket and reed cage gasket. I don't use anything on the head gasket.
    • By ulmanb
      What value would you say a 1986 cr250 with a freshly plated cylinder and new top end, newer tires, newer chain & sprockets, in overall very good condition?
      I picked up the bike (cheap) a month or so ago in need of cylinder replating & top end. Apparently the headgasket blew internally scouring the cylinder. The crank feels good and the bike is very clean/good condition.
      I havent put the bike together yet (too busy to ship cylinder and order parts), but figure I would have a total of $600 (including bike cost) to get it into good running cond.
      A friend wants to buy it as-is for his 15 yr old 200# kid. What value wouldyou put on it in As-is condition vs with a fresh engine?
