Super ignition coil?
They don't add any performance
a gimmick really
Thanks for the about the inner rotor kit? Gimmick too?
No inner rotor kits are awesome!
I wouldn't get a IRK kit on a stock motor, but a 88 or better they are real nice!
They make a 88 rev like a 450r, real snappy, it's the ultimate in light weight flywheels. Most people shave say 20% of the weight of their flywheel off for a 'big improvement' in bigger bikes, with a IRK kit, your practically shaving like 300% of the flywheel weight off!
But some people have had their cast aluminum clutch baskets explode from them.. Personally I had no problem and have at least 50+ hours on my $36 ebay IRK kit with my stage 3 88 kit
gonna be getting a 117 stroker soon, with a billet manual clutch to run on my IRK kit :excuseme:
Thanks again. I may have to purchase this also while i'm buying other stuff. I have heard it's hard to nail the jetting after installing this mod.....Is this true?
Ya it makes jetting harder to get right, since you don't have the big flywheel to keep the bike reving slower so bad jetting 'works'
When I first installed mine, it reved so much faster, my bike would cut out mid rpm for a second, then continue up the revs, and it didn't wanna idle for crap lol... But I played with the needle and air screw and got it so it runs great again :excuseme:
whats your jetting specs? In about a week i'll have the 88cc race head tb big bore kit with 2omm carb, rev box, oil pump, airfilter and jetting kit as wellas the the inner rotor kit. Modded stock exhaust will still be on there and I ride at 0-500 ft above sea level. any ideas?
hey i installed an inner rotor kit i had it sparking and i hooked it too the on off switch and now it wont work...i think it blew my coil...i have a coil from my lil 150 atv and it blew it too cuz now it wont spark on the atv...just for giggles what wires go where just so i know i got it right can someone tell me?
  • Similar Content
    • By RCWSO
      I have an 07 CRF70 that I have done the filter pod modificaiton by cutting the extension tube off and I have drilled a couple of holes in the end of the exaust per some instructions on a thread here at TT.
      I have recently had some problems getting the bike to idle consistently. I am wondering if I should try and rejet the bike at all or get a needle from an older carb that is adjustable. I do have a unifilter that I can put in as well with the stock pod that I cut.
      It is not that the bike wont run or start, it just seems to only idle if I turn it up significantly but as soon as I turn it down even 1/8 of a turn it dies. But the idle that I set to keep it running well is too fast as the bike will move forward if in gear and no throttle is applied.
      Any suggestions? Jetting, needle, air screw change with an older carb?
    • By the-new-kid
      hello guys I'm like really new to this, like extremely new but I was going to buy xr-70r from a friend and drop a Lifan 125cc engine in it (here's the link: ). Now the site says its a 4preed trans with normal gear set up (1-n-2-3-4), and manual front clutch, I'm wondering if I need to buy the clutch lever, perch, and cable then connect it all. Then secondly, what pip should I be looking for I'm not sure if the header would have to be a different style or what exactly.... please be patient with me I'm doing the best I can to learn... thanks
    • By anger806
      hi im new to the forum and i am running a stock 2005 crf 50f with pro tapers but no engine mods what size carburetor should i be looking for to get a little more pep out of my motor?
    • By HondaRacer37
      Hey everyone.  Darn glad to have found this forum!
      Just bought my son a 2009 CFR70 (first bike - 8 years old) and the first thing I'm doing is scrapping the factory air box for a UNI pod filter.
      I'm looking for advice on how I can open up/modify the factory exhaust for more performance.  I heard about removing the screen and drilling some holes but have not found those posts. Any specific advice would be greatly appreciated. (Found only a couple performance aftermarket pipes that were very pricey.)
      I'm thinking after the air filter change and pipe opening the main jet size may need to be increased. It's a stock 13mm Keihin carb.  What size is recommended?  Haven't looked at the stock size yet.
      I assume the needle is adjustable on the slide (but don't know if this would do any good or be necessary anyway) and hope there is an air mixture screw somewhere because it seems the carb could use a bit of adjustment now.  Although next to the idle screw it looks like a brass cap or plug rather than a screw. (See photo attached.)
      Thanks for any advice.  It's great to be part of this group.  Ride on!
      Greg in Florida
    • By thousandbuckle
      Hello all, reaching out to you today to get some help with a small project I am trying to do.
      I just bought a 2006 CRF50 for my 3 year old and would like to rig it up with a wireless remote kill switch for those just in case moments. I have the throttle speed screw installed and will limit it that way also but want a back up until she is proficient and I feel confident.
      Since this bike does not have electric start there is no battery. I was wondering if any one has or knows how to rig up a wireless car alarm system to work as a remote kill switch. I know I will need a 12 Volt battery on the bike which I can get. I know there is a product from 3Built that does this but the range is only 250 feet and some say it is even less than that. I was thinking of a car system since the range is usually around 1,000 feet which is overkill but I prefer overkill when it comes to this topic,
      Any DIY thoughts you might have or suggestions would be appreciated.
