Rebuilt forks = harsh mid-stroke on '06 yz125
Alright, when I first got this bike I was convinced the suspension couldn't be improved much. At about 145lb I fell just about in the intended rider weight range, and right out of the crate, the front end performed like no other tuned-suspension I had ridden with on other bikes.
But eventually the fork had to get leaky, and last weekend I replaced the seals and freshened the oil on both of the twin-chamber tubes. Took it out to the track yesterday and was pleased that there were no leaks, however I noticed the action had become A LOT harsher from the beginning to mid-stroke when going over acceleration bumps out of the turns. There was also tendency to deflect off of them-- which made jumps immediately out of corners just about teeth chattering on the approach.
Everywhere else the fork worked just as well, messed with the clickers (especially rebound) and that helped out some. Later on, I rode a buddies 96 CR125 for a few laps and even his clapped-out front end handled the little bumps better, so I knew something had to be wrong.
Anyway, I'm betting that it's because I added a tad more oil than the manual called for, thinking that it wouldn't hurt... doh. It's my understanding that the inner cartridge balances the excess oil out on it's own when pumping the air out... so do I just dump the oil out of the outer tubes and recycle with the correct amount? And does anyone have a good recommended level that may vary from the manual? It was my first time getting into suspension and I'm not too familiar with the field testing. :excuseme:
Three or four possible culprits.
1.) Too much oil in the outer chamber causing the air spring to be effective quicker in the stroke.
2.) Inner chamber not bled correctly.
3.) What oil did you use in the inner. Possible the wt(cst) was more than previous.
4.) Forks were reinstalled on the bike incorrectly.
Done wright even with stock valving these forks on that bike work really well for most motocrossers:ride:
If you're using stock springs and are not doing supercross or freestyle you should be able to get away with 300-320cc's in the outer chamber.
The inner chamber on these can be somewhat of a pain to bleed correctly. DaveJ has a good tutorial on here just do a search. I use a hybrid method but use a lot of steps from his way.
I would try and find a oil that is a true 3wt for the inner chambers. Something in the 16-18 cst@40.
And most importantly make sure your tubes are parallel when reinstalling on the bike.
Have fun:busted:
Oh and make sure you turn your rebound clicker to full soft before you tighten the jam nut on the cartridge rod to the rebound adjuster bolt. Make sure your jam nut is bottomed on the rod, thread your reb adj on, you'll see a small gap, tighten your jam nut up to the reb adj.
Set your clickers to 10-12 on compression and rebound. That should get you close to stock.
You sir are a gentleman and a scholar. Thanks for the quick reply, and the oil I used was Motul 5w. Some people showed up at my place while I was bleeding the inners and I did the job on both of them while trying to carry on a conversation-- so you're right, I might not of payed the needed attention to get all the air out. Pretty sure the forks are level, so that couldn't be it.
Finding some 3w probably wont happen before I go to the track this weekend, but I'll keep that in mind next time I have to replace the seals/bushings. I'll probably try this again tomorrow after reading that tutorial and stay posted on how it works out.
"have fun," HA! I love working on bikes as much as the next guy but suspension turned out to be a different story... maybe it'll grow on me after a few more times. :excuseme:
From the textbook, viscosity has the most influence when put into a situation of substained shear. Oil flowing past a shim stack does not fall under this condition as the flow surface area to valve opening size is small, hense little shearing. It will, however, influence low speed adjustments as these are long, small dia passages where shear comes into play. Just some input.
Very good input indeed:worthy:
Alright, so upon tearing things down again.. I realized I left out a pretty crucial step-- completely compressing the damper rod after the the inner chamber was re-assembled to get the last bit of air out, so you were on the money. I took my time with the inner cartridge this time and re-filled the outers to 325cc.
Took my bike out to the track again today, pleasantly being rough as hell... MUCH better. Just rode the whole time without even thinking to fine tune with the clickers, maybe next time. Thanks again!
  • Similar Content
    • By Chris Edwards
      Hey guys, I'm wondering what suspension settings you all are running front and rear?  I have a 2017 crf 250r I'm a 210lb newer rider, my settings are currently set at,
      rear suspension low speed  at 12 clicks
      rear suspension high speed 2 turns
       rebound is 12 clicks.
      Left front fork inner chamber 150psi, outer  chamber 10psi, balance pressure 150psi
      Right front fork compression position 7 clicks, rebound 29 clicks
      Sag is 4"
      Thanks guys
    • By Stillwell Performance
      One of the most common calls we get here at the shop is “how do you recommend I go about tuning my suspension?” Good question! The second most common call is “I started turning clickers on the front/back/bottom/top etc. and now I don’t know what I did, help!” The amount of improvement you can gain from proper suspension setup is significant, if you go about it in the right way.
      Look at it this way: if you are 6ft. tall and get in your truck after your 5 ft. 3in. wife just drove it, the first thing you are going to do is adjust the seat/steering wheel, etc. for your size. The same thing goes for your bike’s suspension-last week we had (3) 2010 bikes in the shop for revalves at the same time. Identical models, one guy was a 150lbs. pro racing MX, the next guy was a “B” level GNCC racer and weighed 220, and the third guy was a 180lbs. trail rider. Same bike, three totally different setups!
      So with that in mind, here is where to start:
      • Grab your owners manual, a computer, clipboard and a scale. You cannot effectively start tuning until you determine if the correct springs (fork and shock) are on the bike for your weight. Put down the double cheeseburger, hop on the scale, and get your weight in street clothes. Add in for your gear, which typically runs between 20-30lbs. You can easily check recommended spring rates by visiting under their spring rate calculator. Look in your manual (or ask your tuner) and see what rates are on the bike.
      • If you need to change spring rates-do it first. Trust me on this, trying to tune suspension with the wrong rates is not only frustrating, but you will be short changing yourself on the results. On most bikes the shock spring is easily changed, fork springs can be a bit more difficult-get qualified help if you need it.
      • Even if you are familiar with what “clickers” are, take a moment and read your manual. Determine what style of forks you have (closed cartridge or open cartridge), where the compression and rebound clickers are, and check to see if your shock has both a high speed and low speed compression adjustment.
      • Grab the right tools to adjust, load up and go find a typical piece of terrain to test on. By typical I mean your MX track, hare scrambles course or favorite singletrack. You don’t need to ride a 30 mile loop in order to adjust your bike, rather focus on finding a section of track/trail that has all the different types of jumps/bumps/whoops you encounter.
      • OK here is where I will preach a bit-everybody has a buddy or two that claims to “know suspension” and setup. This is YOUR bike, and unless you plan on dragging him around on the back of the seat the end result of your tuning should be focused on what feels good to YOU. Trust the feedback the bike gives you…..
      • SET YOUR RIDER SAG!!!!!!! This is critical to tuning properly. Again, look in your manual or ask your tuning dude.
      • If you do not have an idea of where to set your clickers, put them in the middle of their adjustment range. This is your baseline setting.
      • Gear up and get warmed up. It is important to be loosened up on the bike BEFORE you start tuning, or you run the chance of mis-diagnosing how the bike is feeling (I never start testing until I have at least 15-20 minutes of warmup time on the bike-I always ride stiff initially and sometimes do not get into a groove until then). Some guys can just jump on and pin the damn thing right from the truck. You know who you are, Wattsy……
      • Remember, this is a tuning session not the MXoN. Use you head and ride at a pace UNDER you max speed-there will be plenty of time to “fang it” once you have zeroed in on some good settings.
      • OK-ride and get a good feel for the bike with the clickers in the middle of their range. Now it’s time to really find out what “too soft” and “too hard” means.
      • Take your clickers and turn them all the way out, full soft. Go ride the bike, but take it easy-it will feel ALOT different. Then come back in and turn everything all the way stiff-go ride again, being careful as this will feel totally different again. For guys that have tuned a bit, these two steps might seem pretty basic, but you will be amazed at the difference in how the bike feels. This is especially helpful for guys who are just starting out.
      • Set everything back to baseline. FROM THIS POINT ON YOU WILL ONLY MAKE ONE ADJUSTMENT AT A TIME!!!!!!
      • So now you will want to determine your tuning range. The tuning range is what settings you will use to adjust for different conditions. For example, If you are an MX racer as well as an occasional singletrack rider you will want to use different settings for those conditions.
      • Fork compression is a good place to start. Ride your test section at baseline, then go about 3 clicks softer. The question to ask yourself after each adjustment is: Does it feel BETTER, WORSE, or THE SAME????
      • There are no right and wrong answers, only what you feel. So let's assume that the 3 clicks softer felt better-go 3 more clicks softer each time until it does not feel as good. You have just found the soft end of your fork compression tuning range. Now return to baseline and do the same thing, only this time go stiffer. After you have found the best compression setting, work on rebound. Remember, one adjustment at a time ONLY or you can become confused!!! Do the same testing with your shock. Once you have both comp and rebound individually adjusted, you can fine tune them to work together-just make one adjustment at a time!
      • As a final test, when you have what you would consider your best setup, write it down, then go back and compare that to your initial baseline, riding both setups back to back. Might surprise you…….
      I could go into some advanced tuning topics about the interrelation of compression/rebound, high and low speed comp, tuning for extremes, etc. but we will save that for another newsletter. Take your time, tune by how your bike feels to you and have fun. You will be surprised by how much better you will ride with well adjusted suspension.
      You can learn more at
      KEEP IT PINNED!!!!
      Alan Stillwell
    • By Jo_nathan
      Selling the showa A kit off of my yz250. It comes with a set of like new x trig adjustable triple clamps. Have 4 rides on rebuild and overall in great shape. Few dings, no dents or leaks. Setup for a 165lb a rider. Work absolutely awesome! I got hurt and cant ride for a year so I'm selling off some of my parts.
    • By Kim Franz
      lookin to upgrade my suspension on my 06 cr250, curious whats possible with some work.
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
