Xr 426
I just finished my top-end rebuild on my 01 XR 400. I bought it earlier this year. It started & ran very well, but it did seem to use more oil than Id cared for. Aprox 1 quart every 1000 miles.
I decided to go with an Polydyn coated Wiesco 426 kit. 11:1 compression. I also replaced all valves with new Kibblewhites. The valve guides mic'd out like new so I replaced the valve seals only.
I've been breaking the bike in for the last few days. The increase in power is very noticeable. Very big increase in torque right off the bottom. Wheelies were amazingly easy in any of the first 3 gears.
Top end there was really not much difference. Im sure a cam would open up the powerband well, but Im pretty happy with just the piston thus far.
The bike starts just as, if not easier than before. I am running it on premium 93 octane fuel & haven't noticed any problems with detonation.
Its definitely well worth the money for anyone looking for a relatively inexpensive mod to do. Especially if you are due for a top end.:excuseme:
Thats good to hear. I have been thinking about a 426 kit for awile. Where did you buy your kit? And how did you go about getting the the cylinder bored out? Can you just take it to a normal engine machine shop?
I bought a Wiesco piston kit, which included a Wiesco top end gasket kit, from Ebay. $155.00
I took my cylinder & head to a local machinist who does machine work for a Moto Dealership I used to work for some years ago. Any machine ship that bores cylinders should be able to easily do the job.
$60 to rebuild the head, & $60 to bore the cylinder, although he said he cut me a deal on the boring.
Definitely a great bang for the buck mod, especially if you do the wrenching yourself. :excuseme:
Its worth doing if your rebuilding anyway, good usable torque gain while only sacrificing a little bit of rpm. The money saved by boring rather than resleaving will almost pay for a cam if you want to liven up the powerband a bit more. No heat or reliability issues that I've found so far with the thinner liner.
I'm not familiar with that coating, what does it do for the piston?
BTW, thanks for the report! :excuseme:
Coatings reduce friction and keep detonation at bay.
ZO6PSI is correct. The coating is mainly to reduce detonation & prolong the life of the piston.
Here is a link to the coating.
The are used a lot in the forced induction world in high performance cars. I have a set of Diamond coated pistons in my supercharged Corvette.
How many miles on break in so far? I noticed on my 280 it took awhile before the power was completely there.
I have a few general big bore questions.
416, 426 you bore the stock liner? And 440 you fit new liner?
Do all 440 kits just increase bore or are there some that increase stroke?
How easy is it to get replacement head gaskets (and base gaskets for bigger liner)?
Sorry to hijack thread, that is a nice looking piston.
Hi Garth,
Yes, all use the stock sleeve/liner except for the 440
All 440 big-bore kits only increase bore. They probably sell 440 stroker kits, but they would cost much more to install than a piston/sleeve kit.
Replacement gasket kits are readily available. The kit I bought included a top-end gasket kit that matched the new bore size.
RedRider3141, I have less than 20 miles on it as of right now. Hopefully she will free up a few more ponies after it is properly broken in.:excuseme:
  • Similar Content
    • By Kev_XR
      If you own an XR250, many of these tips will apply, however, the carburator jet sizes will be different.
      It really helps others answer your questions.
      I will fix them as time allows.
      Until then the Search Feature and enter "kevin's xr400 mods".
      The results will bring up most of the links.
      Here are some frequently asked questions I have answered before.
      Which XR should I buy?
      The longer the straights, the taller the hills, the deeper the sand; the bigger XR you want. The tighter the trail, the smaller hills, firmer terrain; the smaller XR you want.
      The XR400 has a great motor that will pull you almost anywhere. You can be sloppy on a hill climb on an XR400, where you have to keep the 250 singing. The XR400 weight is most noticable when you drop it or try to stop it going down a long downhill. (Moooomentum!)
      The XR250 feels like a mtn bike compared to the XR400. My friend rode his XR250 for years before decided he needed more power. Even then you can add a 300 kit and get good power.
      If you were heading to ride fireroads in Baja, I'd tell you to get the 600/650.
      To the tight woods, get the 250.
      A lot of both, the 400.
      Dual-sporting? Go bigger for more freeway, but don't show up at the trailhead with too big of a bike.
      All of the XR's are great. Pick the one that fits your needs.
      Gordon's Mods for XR400 (Uncorking the bottle up performance)
      XR400 History
      The changes to the XR400 have been listed here several times. This list appears to be complete.
      In addition, HairyScary discusses how to tell if a part has been updated by the part number. Good tip!
      XR400 history
      Getting the Spark plug out
      It seems the MotionPro spark plug socket does not work on the XR400R, but works on the XR250R.
      There is an OEM tool kit being sold on eBay that seems to work.
      717448 XR400 oil change
      Here is a way to make changing the oil much cleaner.
      This tips is really handy if you have a skid plate.
      XR400 oil change
      XR400 FAQ by Paul Gortmaker
      Paul usually has very good info.
      Small bolts
      BE CAREFULL with the bolts on the oil filter cover!
      An oil covered bolt will not torque at the same rate as a dry bolt.
      The friction doesn't build up, the force simply builds until the threads strip.
      This is the reason many people strip out these bolts.
      Here is an execllent website on bolts, oil, and misc values.
      Did you ever wonder why a 8mm box wrench is half as long as a 18mm box wrench?
      It is shorter as most 8mm bolts cannot take very much torque.
      I highly recommend getting getting an 1/4" socket set.
      I bought the Craftsman set at Orchard (owned by Sears), which tends to sell them for less.
      What is the Snorkle?
      This place has a description and pic, it's easy after you pull the seat. I siliconed a piece of coarse screen (fiberglass) over mine to keep bugs and stuff out. - NORTEXT
      717439 XR400/250 Pre-Filter
      After pulling the snorkle, there is a big hole on the top of your XR400. My friend showed me this prefilter trick.
      767409 XR400 Engine Bog, Pilot jet, and the Fuel Screw
      On XR400's twisting the throttle from fully closed to wide open will cause the engine to "bog" or in some cases die.
      831305 Valve adjustment (Am I retarded...)
      Inspect and adjust valve clearance while the engine is cold (35C, 95F).
      Valve adjustment
      389095 bigger jets (Lists stock jet sizes.)
      96-97 XR400's were jetted assuming you would remove the intake and exhaust snorkel.
      98 and later XR's were jetted assuming you would leave them in.
      bigger jets
      739907 Cheap Tool for Setting the Fork Oil Height
      There are some really nice tools out there for doing this job.
      This tool costs $4.49 at Kragen.
      Cheap Tool
      392932 high altitude jetting
      There are two big factors for jetting, elevation and temperature.
      Allen screws for the XR400 carb
      This lists the screws you need to convert the XR400 carb to use allen screws.
      Allen screws
      Screws for the brake and clutch after removing the stock handguards
      TBD - There is a post with the shorter screw part numbers for after the stock handguards are removed. Use search.
      Very quick engine hop up
      This is a very minimal change that should take less than an hour.
      Most of that time is removing the float bowl (3 screws).
      If you decide to do the full "Gordon's Mods" later, you will need to replace the jets again.
      o Pull the intake snorkle.
      o Add a UniFilter.
      o Pilot jet to 55, main jet to 155. (Assuming sea level and moderate air temps.)
      Source: Motocross Action magazine.
      Quick engine hop up
      Gordon's mods
      Baja Designs Baja Baffle with 96' spark arrestor.
      Pull the intake snorkle, UniFilter, 60 pilot jet, 162 main jet.
      (Depending on altitude and temp.)
      What to add to a new XR400 or XR250?
      Acerbis wrap around style handguards (saves levers and bars as they don't dig in)
      Baja Designs skid plate (Made by Utah Sports Cycle)
      Acerbis fork/disc protector
      Grease headset and rear linkage
      Spend you money on the suspension, not a pipe!
      First get some stiffer fork springs (96-97, 98-99 years)
      Fork revalve (cost: 2 qts of oil & time)
      Shock revalve (cost: oil, nitrogen, shim stack, friend who knows shocks)
      Jetting for Altitude (XR400)
      Assuming at sea level and 68 degrees, you would use a 60 pilot and 162 main.
      At 5000 feet and 68 degrees.
      Jettting correction:
      Main 0.96 * 162 = 155 -> 155 main
      Pilot 0.92 * 60 = 50.6 -> 55 pilot
      Due to your elevation, you have less air and less fuel.
      Your bike will not behave the same as a bike at sealevel.
      First, check the fuel screw. If it does not affect the idle speed, you have the wrong one.
      kevin's xr400 mods
    • By Child
      Can we make a sticky thread of pictures? I've done search for pics but I want to see all sorts of bikes just for ideas on stuff without having to go through tons of threads. Not trying to sound whiny or anything, but I think it would be nice to do what they do in the CRF250X forums with a sticky thread of just pics, no comments or anything. Think we can get one of those rolling here?
    • By kawamatt2
      Ok guys, add one more to the list of riders attempting the USD fork swap to an XR frame. Quite a bit of research here on TT and ebay hunting brought me a pretty good deal on a set of forks, triples, and stem from a 00' CR 250.
      There are a few different options for adapting CR style forks to an XR. Bushings for upper and lower CR triples can be made to allow use of the stock XR stem. Specialty bearings can also be purchased to allow use of the stock CR stem in the XR neck. And finally what seems to be the most common; modification of the stock CR stem to allow use of XR sized bearings.
      I obviously chose to pursue the third option for a few reasons, the most prominent of which is serviceability. I wanted to keep as many wear items at possible as stock parts. This has two advantages; availability and price of replacement parts. $45 dollar a pop "specialty" thin section tapered bearings don't sound too appealing especially when being used on a 12 year old dirtbike.
      So now we can get to the meat of the issue; modification of the CR stem. I should begin by saying that i am NOT a draftsman. I've taken a few classes on engineering measurements but am far from an expert and probably only mildly proficient reverse modeling components. With that said, the first order of business was comparing an XR stem and bearings to a CR stem and bearings. Shown below.
      A little closer look at the XR setup.
      And the CR setup.
      Now to get out the calipers and model up the stock CR piece. I used a cheaper set of calipers and suspect their tolerance is +/- .01mm. Good enough for gov'ment work though! All dimensions in millimeters.
      Now to modify the CR stem to work with the XR bearings while remaining compatible with CR triple trees. There are a few things to say about why i did some things the way i did but most of the thoughts are included in the notes section of the drawing.
      With a resized stem we run into the problem of mounting the top triple clamp. The hole is too large for the stem. An insert bushing must be made to resize the hole in the clamp.
      Finally what the stem and bushing look like together.
      Last one. The difference in how the top triple clamp is located on the stem. The CR is equipped with a chamfer that provides a stop for the tree while the XR's triple appears to be limited only by the threads for the castle nut.
      So... would like to hear your opinions on the execution of the stem modification and bushing. I think having these drawings will make it simpler to have the modifications performed as opposed to asking the machinist to completely reverse engineer the part him/herself.
      And a final query: Anyone know the thread callout for the two threaded portion of a stock XR steering stem? My drawings show the outside diameter of the threaded portions and i have a cheap plastic pitch gauge that tells me a pitch of 1.0 but i am looking for something more concrete than what i have.
      Thanks for your thoughts and opinions.
    • By ATJ_Number_1
      I'm on strike 2 here but thankfully this isn't baseball.
      The reasoning and my history. If you haven't figured it out yet I've done a crap load of work on these motors over the last 7 years but they have had 4 wheels around them. In the EX world there are a lot of carburetor options and although many are great there's a cheap alternative that runs 95% as hard as the high dollar options, some even liking it better then aftermarket. When I joined up here in the 2 wheel club I was shocked that the only accepted option was $400 for a 36mm Mikuni Pumper that isn't any bigger then stock! That cheap alternative for the EX is an 04-05 trx450r carb. It's 42mm round slide Kiehin piston-valve with accelerator pump and a mildly modded 400 loves it with a surprisingly strong bottom end yet. Yes I said 42mm!
      So as I build my XR4 I already know that I'd be shooting myself in the foot if I settled on a 36mm carb because I like bigger bores and cams and this motor likes bigger carbs. Makes sense, it is 400cc. Don't get me wrong though, the Mikuni is a real nice pumper for a stock bike and would seem fine on a well modded machine too but this 4 stroke is like every other one in the world in regards to when you go big inside, you want to go bigger outside or you're missing out.
      Whether the info is appreciated or scoffed at I'll post up my findings one by one as I try to find viable alternatives. When I say viable I mean still being able to use the stock environment and not needing a ton of work. I'm sure collectively this is not a new idea to search for such a beast but I enjoy a good project and I like cheap alternatives when they produce results.
      Currently the "test bike" is a 2000 Xr400r, snorkel removed, Uni filter, stock engine, stock headpipe and a 4" supertrapp slip-on with 11 discs.
    • By XL100allnightlong
      Just wondering if there is any tricks to polishing the stock headers on an 02 xr 400 to bring back the original copper color? If not ceramic coating them sounds like an option?
