need help with 05crf250x
I need help with what to look into next, my son rides this bike and his bike recently has became hard to start, within the last couple rides. Now I cant get it to start using the button or by kickstarting, it will jump start. I've checked out everything I know to check. I've cleaned the aircleaner even though it wasn't bad, checked to make sure it is getting good spark,it is, and plug looks good, it is getting good fuel flow, and I checked to see if the jetts are clogged and the battery has a good charge. I dont know what to look at next, so if you out there might know PLEASE hit me up with some advice. My son looks like he just lost his best friend, I've got to get it running before sat. big ride for us and he dont want to miss it. So please help!!!!!
valves need to be checked.
ok I've checked the valves and the exhaust is .011 and the intake valves are supposed to be.005,well there so tight I can't even get .002 to go. Atleast their not loose rite, so van you tell me is this good or bad and what my next step should be.
time to re shim it, back to orig. spec. thats the next step.
I would rather have them loose, but that's not the case. You can shim but that may not help for very long. Usually this is an indicator of it being time for a new head (or rebuilt one) and new valves. The upside is you usually get warning signs before they go south again. Good luck! Hopefully you can get plenty more hours out of it before having problems again. Just keep an eye out for problems getting it started. If you encounter hard starting in future, leave that bad actor in the truck or it could leave you in a bad way in a place you don't want to be.
Thanks for the help everyone, thanks alot!
Re-shim and start saving for the valve work. Some people have had some luck just throwing in new valves....but that risks trashing a couple hundred bucks worth of parts.
The seats will need to be recut, and valve guides checked/possbly replaced.
I used Ron Hamp Cycle's to have my head reworked. I think he is a very honest businessman. He returned part of the fee, as not all work quoted was actuall required after inspecting my head. He also was quite honest about what would actually be beneficial for my bike.
i reshimmed mine and it started first kick
How many hours since you reshimmed?
only one ride so far, maybe like 4ish hours. just did it last week
Post again when you have to reshim it again, by all previous experiences it should not be long.
most likely next ride out......
Yeah, I didn't want to jinx him though, Maybe he will get 10-15 hrs out of it.
lol well ok then.....
When mine started to go, it was no more than 5 hours after I had to re-shim the second time, and then I shimmed it almost every 2 hours, till the valves 0'd out. I had Ron Hamp send me an R head that had all the work done to it and I haven't had to re-shim since.
i bought my '05 in '07 and by early '08 had shimmed and re-shimmed all i could. it's the light titanium OEM valves that wear out so fast. I dropped the big money on the steel Hepplewhite valves last year and haven't adjusted them or had a starting problem since
It is a rapid decline! once the shims need doing, the valves are getting shot. but also check the valve seats. I know a mate who did new valves on a Suz RMz. but he still has to reshim after each event, or hard training session. it just becomes a pig to start when it is cold. His valve seats are clearly at fault. the suzuki inserts are very similar to the Honda...same construction and composite.
  • Similar Content
    • By Connor Wright
      Hey I have a crf250x 2005 I was riding today in top gear flat out and when I slowed down blue smoke just poured out the exsaughst then I happened to open the air box lid and saw it has what looked like engine oil in it then took out air filter and noticed that there was splatters of engine oil on the inside and that and the channel that goes to the carby had engine oil all over it.
      Also bike got a top end rebuild 15 hours ago
      The engine still runs good and sounds normal
      why would this be happening on a resonabley fresh engine
    • By mikemcbride
      Hey everybody. Quick question for y'all. I recently went riding and about halfway through my ride my motor seized on my '07 CRF250X. I haven't investigated it much but I checked the oil when I got home and there basically was none so I'm assuming that was the culprit. There weren't any metal shavings in the filter or on the plug either. At this point I'm trying to decide to rebuild the motor or just sell the bike as is and let the next buyer deal with it (they would know the deal obviously.) I feel that I'm pretty mechanically inclined but rebuilding a CRF engine is a bit out of my league and I assume paying a shop to do it would put me out more money than the bike is worth. So, I have this question to ask; what would be a fair price for a pretty dang nice shape 07 CRF250X, with a seized motor with an unknown extent of internal damage?
    • By ThomasM.
      selling Hot Cams Valve Shim Kit that i bought for my 2005 crf250x, will also fit crf250r.
      used 1x 1.30 and 2x 1.55 shims. the rest is still there.
      $60usd shipped in the usa or canada
      please contact me for pictures or if you are not sure if it will fit your bike
    • By TerryA
      I have two rides in on my new Rekluse auto clutch and I have to say I'm very pleased. The install wasn't hard, but was pretty much a all afternoon sort of project. I also installed a left hand rear brake kit and a two finger cluth over-ride with the adjuster on the perch (which I rarely seem to need). It has all worked great right from the beginning. After struggling to get up a tricky hill in first gear, I tried it in second and the autoclutch helped me clean the hill easily. Not having to worry about clutch action in techinical sessions has also eased fatigue and just made it more fun all the way around. I ride mountain bikes alot, and having both brakes up on the bars has also been nice as it makes for a set-up just like the bicycle - in fact I like that as much as not having to worry about clutch manipulation. The brake on the bar is especially nice on tricky downhill sections where you need to paddle, such as nasty rock/rut stuff. So first impressions are that it was worth the investment -making the ride more enjoyable and easier at the same time!
    • By Mikey560
      I was driving the bike for 15min or so and all of the sudden the bike stalled. I tried starting it again with no luck. I took the spark plug out to see if there is spark so i ground the spark plug to the frame and there is no spark. I even put a new spark plug in the bike and still nothing. Any ideas what i should check??
