Confused
I have a bunch of tight and loose spokes. If i follow the "every third one at 1/4 turn" rule, doesnt that mean they will still all be uneven? Can I just tighten them randomly until it gets that ring sound when I tap it? Thanks
you tighten every loose spoke, but if it is already tight move on 3 again,
you may have to do several runs around because as you tighten on side it will loosen the other, and only turn 1/2 a turn at a time, this helps keep the wheel true,
