Tire Hand Pump Suggestions
I planning on carrying a hand pump to inflate my tires as needed or when I need to change a flat on the trail. I have an XR400 with typical 18" and 21" tires and run between 15-25 PSI.
I looked at REI a few days ago and they had a bunch but most seem suited for high pressure/ low volume bike tires. Has anybody found one that works well for motorcycle tires?
I have used an old mountain bike tire pump to air back up after an off road section. It only took a few minuets, although a lot of strokes, to air the tires up from around 14 psi to 22 psi. I have not yet had to change a flat tire on the trail so I dont know how long that would take. My old pump is about an inch in diameter and about 6 inches long, but it telescopes when using it so it works suprisingly fast.
Something like this works good. Fits in my fender bag and will inflate a knobby (Tired it before heading out on the trail and it worked!) Blackburn has a bunch of different models and are available at most bike shops.
http://www.amazon.com/Blackburn-Mammoth-Stage-Bicycle-Frame/dp/B001GAOR34
+1 on the Blackburn. You can check your local bicycle shop or go to Jensonusa.com or Pricepoint.com and they usually have some decent prices on their pumps. A dual action/two stage pump will save you alot of strokes forsure.
Anyone try one of these 2nd wind CO2 / pump units?
http://www.cycoactive.com/mc/swmtb.html
Yup. CO2 portion works great. Hand pump works, but takes forever...not a lot of volume there...
they work good and dont take up alot of space. some do leak after used always keep extra co2 on hand.
I carry one similar to that one along with a pump just for good measure. The good thing about the one in your link is you can use both the threaded & non threaded co2 canisters where as mine you can only use the threaded type which can be a little harder to find sometimes.
+1 Blackburn "Mini" fits in my old dich Burleson leather fanny pack. Plus threaded CO2 & thread adapter for bottle to schrader
Good quality mountain bike pump (more volume per stroke)- Dick's sporting goods.
Dave
The Topeak Mountain Morph looks like a good choice. I have been very pleased with the Topeak Road Morph for my bicycle, the Mountain is a higher volume lower pressure version of the same. I like the fact that both of these have a short flexible hose to connect to the valve. I've broken too many valves and pumps on bicycles with the had connections.
Craig
Second wind, C02 and pump.
Craig
You read my mind, this is the one I've been looking at.
As for those that recommended a combo CO^2/pump, how many tires have you actually used these on? I like the idea of a pump back up, but I'm still not convinced the Co^2 canisters are great for a motorcycle tire.
I used one for about 3 years it recently exploded in my hand when using the CO2 inflator (didnt get hurt), it must have been already cracked before I used the CO2, it has lasted longer than I thought it would, I would buy another.
Yes it is low volume, but it is very small too, I dont mind the extra pumps it takes vs the size, worth it IMO.
I went to the bike shop and bought another one, didnt look at the package well enough and it turns out I bought the CO2 inflator only, has no pump, thought it just looked different because it was a newer model...oops
2cd Wind and an extra C02 is all you need.One C02 should pump up a motorcycle tire with no problem.I have one but havn't had to use it yet.I did use the hand pump on my quad to add a little air,Its slow but it is very small and packable.I got mine at www.Rockymountainatv&mc
Go to Wheeling Cycle, they still have a DRC foot pump on clearance, I think for $15. I bought one and it works well and doesn't take up much room.
I bought a made in USA tire pump at wally world, then cut it down to fit in my top case. I made a 2 foot pump down to 14 inches. Airs up the tires with 10 to 15 pumps on each end. Cost $9.00
