Kickstarter assembly
hello
I just put together my kickstart assembly and was wondering when I install it in the case, is there supposed to be any spring tension on it from the main spring?? right now I just dropped it in, it doesnt say anything in my manual at all. I'm I supposed to put it in a certain way ?
thanks :excuseme:
no1clydes pic for reference
KX250%5E1999%5EKICKSTARTER%20MECHANISM?$oem$
hello
thanks :excuseme:
there should be some tension, the spring has a pin that goes into the kicker shaft, then you preload it and drop it in the hole in the case, just like no1clydes is.
