Front bearing YZ250
It might be the same as a similar year YZ250. If you have access to a new year 250 cross check the part numbers. If they match measure the bearing.
Front wheel diameter bearing YZ250 1996?:excuseme:
I notice you are from Russia. Welcome.
Do you have motorcycle shops and motocross there? How cool would it be to hit the local raceway in full Russian MX gear! This web sight is good for bearings. http://www.bikebearingshop.co.uk/C2.htm
Match the year, do a search on the bearign number, and its easy to find one from there.
Of course there are motocross in Russia!
With shops motocross bad ...
But there ebay.com:)
Front wheel diameter bearing YZ250 1996?:banghead:
http://www.vxb.com/page/bearings/PROD/Kit7606
6904-2RS Bearing 20x37x9 Sealed
Always double check your dimensions before purchasing any parts.
But there ebay.com
If you are buying from eBay, then look for All Balls wheel bearing and seal kits for your exact year and model.
http://cgi.ebay.com/ebaymotors/FRONT-WHEEL-Bearing-Kit-YAMAHA-YZ-250-YZ250-1996-1997_W0QQcmdZViewItemQQhashZitem4a9bec86d2QQitemZ320443549394QQptZMotorsQ5fATVQ5fPartsQ5fAccessories
thank you!
