Western NY dual-sport riders ?
So, i plated a brand new 2004 E model and have ridden probably 10 miles of roads. I really can't find anywhere to ride that's fun and legal. Any other DRZ'ers in Rochester area who know of good dual sport loops ? I know this might not be the best spot for this thread but i would like to get to know more DRZ owners in the area. There was a dual sport ride in Avoca NY in September but i missed it. I want to put some miles on this thing before winter sets in ! Anyone ???:excuseme:
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
