434 Big Bore starting
Is a 434 big bore much harder to start with the stock starter/battery setup?
Not really. It`s when you put a stroker crank and perhaps aftermarket cams with out auto decompressor on it that it gets harder....:excuseme::thumbsup:
Starts just as well as a stock motor. Charged battery, servicable starting system, properly tuned.. No issue
Just what I was hoping to hear, thanks!
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
