Clutch cable work-around-fix
Thought I would share this info I stumbled upon,when I couldn't get a clutch cable in time for my next ride.I did a search and couldn't find anything so thought I would share
> Replace the steel cable in the old sheath.
> I broke the clutch cable on my bike before a big ride and
> couldn't get a replacement in time. So I
> pulled the steel cable out from each end and left the sheath
> in place on the bike.
> Using the old cable to match to, I found a spare throttle
> cable w/ a barrel end that would fit my clutch lever &
> was a little longer than my old clutch cable. A
> bicycle cable from Walmart might work too.
> I snipped off the stop on the clutch arm end, and removed
> the steel cable from the throttle cable. I lubed it
> and inserted the steel cable thru the broken clutch
> cable's sheath. I then threaded it around
> the clutch arm and used a cable stop from Advanced Auto
> Parts to hold it tight.
> It worked fine. If you're worried it might break,
> buy a few spares.
Good luck and have fun.
I don't know if this is in the right forum or not so if not move it to where it can be better found
