What fork oil level do you run?
I just went to stiffer fork springs (.46) to reduce bottoming. I would like to get just a little plusher feeling over the sharp edge stuff. Should I lower the oil level or just try the clickers first? I would like to here what other X riders have done.
I would have put it there but I really want to keep it specific to CRF250x owners.
Try the clickers, set em both at 12 and go from there. The biggest effect of the heavier spring you may notice while riding is the front end will be riding higher in the stroke, which will change the way the bike turns. You might want to slide the forks up a hair and or run less rear sag to get it to turn the same. Unless you know exactly where the oil level is now I wouldn't
try to adjust that too much.
Edited by highmarker
Fork fluid level doesn't have any impact on fork action until you reach the last couple of inches of travel--at that point, the change in fluid volume produces a change in air-spring effect. Adjust your compression clickers to a softer setting--when I went to stiffer fork springs I had to go down to 6-8 clicks from full soft.
Roger M--04 X
I usually service mine with the min oil in and adjust up a little after a couple rides. Like mentioned it doesn't effect the high speed much. I have noticed keeping the air bled can make a big difference though, good quality dual seal speed bleeders are worth the investment.
What are you running for preload? Less preload will give you a plusher ride in the early part of travel.
JayC
JayC
I wish I really knew enough to answer your question. I put the stock spring seats back in. Isn't that what would change the preload? How much less preload are you talking about? Thanks....
Actually, I'm not sure that the forks give the ability to muck with preload. However, the CRF forks have a little spring (which has a name that I can't remember) that sits on top of the main fork springs. I think the little spring has it's effect in the early part of travel.
You should post your question in the Suspension forum - there is enough CRF experience in there to give you a better bike-specific answer.
JayC
  • Similar Content
    • By Hayden Ploeger
      So I have never actually posted on one if these forums. I usually just stalk them to get answers but I messed up and I might be out 800 bucks🙃
      I have a 2013 CRF250L that I recently bought and I wanted to get supermoto wheels for it. I got online and almost ordered a set of warp 9 wheels but then I saw an add on Craigslist. Long story short I purchased lightly used warp9 wheels from a 2012 CRF250X not realizing the axles are different sizes. The rims are the same size as what comes in the kit from warp 9 but the spacers and bearings are larger on the wheels that I got. Does anyone know if I can buy new bearing and spacer kits to go in these hubs to fit them on my bike or will I need to purchase new hubs entirely?
      I work on a fishing boat and I'm off the coast of Oregon for a few weeks and wanted to order something so I can get these wheels on my bike when I get home.
      Thanks,
      The guy who f***** up
    • By yrun
      I have a new 16 crf250x.  Would like gear it up a bit for two track, orv trails.  How much can i drop the rear sprocket size without shortening the chain.
      Thanks men!
      Joe
    • By yrun
      I was working on installing new needle for JD jet kit today. While trying to get a bit more rotation on the carb i broke a little plastic tee on the top of carb (left side). I think its some sort of vent? Not sure if the brass part is threaded into carb or not? At any rate it will have to be replaced. Wonder where i'd get this little item?
      Any ideas?
      Thanks joe
    • By ronbuell
      Ever been bored or really ticked off by not being able to reach your fuel screw for trailside adjustments?  Well, I decided to do something about it, and not spend a bunch of money to boot!
      Parts liste included:
      Short length of brass tube. Short piece of old, broken speedometer inner cable. Nut from the rejects bin.   I welded the nut to the speedometer cable inner and soldered the other end to the fuel screw using the brass tube as a connector.  I didn't need or fab up a holder for the end, but I wouldn't be too hard. My DIY flexible fuel mixture screw works great and the price is right! I highly recommend this mod.
      Cheap, but effective DIY fuel mixture screw
    • By Frana
      Hi everyone. I’m new here so I don’t really know what to do but let me explain what’s up, so I bought this 2008 CRF250X today and everything looked in tip top shape, but within a few minutes of riding the engine and radiator gets to hot to touch and then the bike dies at low RPM, then it is a hassle to get it started(i drained the battery trying) and once it fires it dies super easily again like by touching the trottle or just idling and I have to be super cautious on the throttle to grt it going. I don’t know if it is overheating or if there is another problem, if anyone could help me it would be very much appreciated.
