Help - Oil Problem
Last ride noticed oil very dirty after one ride. Almost a silver/metallic look
Came home changed oil and started and did 4 heat cycles...no clutch
Oil very dark and either bubbles od metallic look. let sit and just turned dark.
Drained oil again, refilled and aran one heat cycle. again dark but not as dark..same metallic look at first then just kind of dark green.
Very worried!!!
BTW, just read some previous posts on the same issue. I drained the oil per the prodedure listed here. I did three successive oil changes...same problem...dark metallic look....low viscosity. poured oil into glass jar and let settle...still looks like it has very fine metallic particles
