Jetting altitude conversion chart/graph
Does anyone have a link or download for an altitude converison chart/graph for jetting changes. Thanks
Hey, here is a formula that I found. CF=1.0778-.00111*T+(2.38554*10^-10)*A^2-(1.0777*10^-5)*A Where CF is correction factor, T is temp in Farenhieght. A is Altitude in feet .* stands for times, ^ stands for power. So 2^2, is 2 to the power of 2. Then you take the CF times your current jet size that works for sea level. and thats aprox your new main jet. Your pilot is to taste. same as leaning out or raising your needle clip. Rule of thumb .96 and above leave alone. .91-.95 lower clip one notch. .90 and below lower/lean two notches. Remember I'm just the msngr, do your own careful calculations and jetting and dont try this at home. Cheers
