drz 400 sm 06 , strange noise
Hello, nice to say hello, sorry for my bad English, but I'm from chile, try to explain as best as possible
my DRZ 400 SM, has a noise, but that occurs only in certain RPM and being in neutral, first or second, climbing rpms, not sound, if for example it changes pace accelerating fast, barely noticeable, I have tried to catch him at third, fourth and fifth and does not sound, is a noise like something hitting or anything was loose.
I thought the patent was vibrating with escpae (has a Yoshimura off road), but it is not clear .....
I can not identify which one is good, but I think the engine or on and near the right side but I would say.
case of uploading a video then
Well, thank you very much!
Greetings from CHILE :moon:
It could be the automatic decompression release on the cam shafts. That seems to be a source of noise.
A video is the bet way for us to tell.
It's pretty hard to understand all of your posting, does the slapping noise happen when you are in a higher gear than you should be, in other words, you need to downshift to get your rpms up?
