03 TTr parts and advice wanted
Hi I live in the Seattle area and I'm trying to get my used 03 ttr 125 running I need the following
Carb top cap with bent metal throttle cable housing
throttle cable
counter sprocket with chain
I'm curious if anyone on here can sell me a better Carb or if I should rebuild the stock used one
thanks for the help-Neal
Sorry I can't help you with the parts, as most of them are being used.
If nobody can give up the parts, rebuilding the carb would not work...
You can use a carb off a CRF150F, but you have to buy the jets to tune it for the bike. Motion Pro makes a throttle cable that can be had for around $25. It's about 3" longer, but can be routed to help make up for most of the slack. Try Bent Bike in Auburn or Lynnwood, and ask if they have anything that might fit. VM24 is one of the more popular conversions.
As far as any other carb - Outer Diameter should be within a mm of 32mm on the outlet side and 42mm on the inlet... and you can't fit a pumper type carb in the limited room under the tank. You'll need to rejet, and it can take a lot of time and money getting things perfect.
Hope this helps some.
-Kerry
