CRF Injection Pump
Looking for information on the Keihin injection pump fitted to the CRF 450R.
I am model number and specs.
If you cannot help , do you know somebody who can ?
Grateful for any help.
:moon:
Not sure what info you want?
Do you mean the fuelpump on EFI bikes or the accpump fitted on the carb on pre 09?
Could bee im a swede, not familliar with the expression "injection pump" :moon:
Kalle:sweden:
It is the fuel pump mounted in the bottom of the tank.
The info needed is flowrate , working pressure and relief valve pressure.
I don't even think Honda has that published anywhere...Time to order one and test for yourself ! Since they are all Keihin designs, I'd guess all the 450/250 FI systems are running very similar fuel pressures.
Does anybody know the Keihin model number for the pump. Then I can contact Keihin direct. Thanks and Happy New Year.
Perhaps you can just call Keihin and ask them what the PN is... I bet they'll be able to help you out if you tell them what the bike is... Sudco might be able to help, as well.
Here is what I found.
Fuel Pressure- 333-353kPa (3.4-3.6 kgf/cm2, 48-51 psi)
Fuel Pump Flow- 50cm3 (1.7 US oz, 1.8 Imp oz) minimum/10 seconds
Hope this helps
Matt
